Good news: Cursor keys working in GRASS shell windows
Markus Neteler neteler at geog.uni-hannover.de
Tue Jul 6 04:57:46 EDT 1999
Hi!
On Tue, 6 Jul 1999, Phisan Santitamnont wrote:
> > - RETURN cycles through the input lines (as usual)
> > - cursor keys left and right are working (new)
> > - cursor keys up and down are working (new)
> > - ESC-RETURN take you out of the screen (modified)
> can i get the code to patch into 5.0
Yes, find it attached.
Replace this V_call.c with original version in:
src/libes/vask
Please save the original file first!
It works for GRASS 4.2.1 as well.
Cheers
  Markus
#define TELLME(x)	fprintf(stderr,"V_call %d\n",x) ;
Modified by Jacques Bouchard and Markus Neteler 6/99 to make cursor
keys working. Exit now with ESC-CR.
FUNCTION:   Interactively allow the user to enter answers into all
            available fields (as previously defined).
            Answer fields have been created with calls to V_ques()
            Information fields have been created using V_const()
            General text has been created with calls to V_line()
USAGE:      V_call()
PARAMETERS:
RETURNS:    1 user entered ESC to continue
        0 user entered ctrl-C to cancel
ALGORITHM:
        |   Zero out screen answer locations
        |   Initial curses screens
        |   Display text, constants, and answer fields
        |       Write text      (results from V_line() calls)  to curses window
        |       Write constants (results from V_const() calls) to curses window
        |       Write answers   (results from V_ques() calls)  to curses window
        |   Take commands from the keyboard
        |       switch on commands:
        |           case CR: case NL: case UP: case ESC:
        |               switch on answer type
        |                   case string
        |                       remove trailing non-alphanumeric characters
        |                       copy answer to target denoted in V_ques() call
        |                       blank out screen line
        |                       copy target to curses window
        |                   case integer
        |                       run atoi on answer, putting results in target
        |                       printf target to curses window
        |                   case long
        |                       run atol on answer, putting results in target
        |                   case float, double
        |                       run sscanf on answer, putting results in target
        |                   default:
        |                       do nothing
        |               if ESC+CR return from V_call()
        |               if UP  shift to previous question
        |               if CR or NL  shift to next question
        |           case BS:   Move cursor back one column in current question
        |           case FS:   Move cursor forward one column in current
        |               question
        |           case RPLT: Replot the current screen image
        |           case DUMP: Dump (append) the current window to the user's
        |               home dir.
        |           default:   If an alphanumeric, put that char on the screen
        |               and in the current answer field
        |   call V_exit  (erase screen and exit curses)
CALLS:
        V_init()        Vask routine to initialize curses
        V_exit()        Vask routine to exit curses
        V__dump_window()   V_ask
        V__remove_trail()   V_ask
        addch()         curses routine
        addstr()        curses routine
        move()          curses routine
        putc()          curses routine
        refresh()       curses routine
        getch()         curses routine
        wrefresh()      curses routine
        sprintf()       UNIX
        strcpy()        UNIX
#include "vask.h"
/* define the V__ struct defined in vask.h */
struct V__ V__ ;
#define DUMP	001
#define BELL	007
#define BS		010
#define FS		014
#define NL		012
#define UP		013
#define CR		015
#define RPLT	022
#define ESC		033
#define CTRLC		003
#define TARGET	V__.usr_answ[at_answer].targetptr
#define ROW		V__.usr_answ[at_answer].row
#define COL		V__.usr_answ[at_answer].col
#define LENGTH	V__.usr_answ[at_answer].length
#define TYPE	V__.usr_answ[at_answer].var_type
#define ANSWER	scr_answ[at_answer].position
#define RELINE	move(ROW, COL) ;                       \
				for (incr2=0;incr2<LENGTH; incr2++)    \
					addch('_')  ;                      \
				move(ROW, COL)
/* flag ctrl-c is to be allowed */
static int interrupts_ok = 0;			/* mod shapiro */
V_call()
    int incr ;
    int incr2 ;
    int num_answers ;
    int at_answer   ;
    int at_constant ;
    int ans_col     ;
    char newchar    ;
    char lastchar = 0;
    int c;
    struct { char position[80]; } scr_answ[MAX_ANSW] ;
    long atol() ;
    int y,x;		/* shapiro */
    char temp[100];
/* Zero out screen answer locations */
    for(incr=0; incr<MAX_ANSW; incr++)
	    for(incr2=0; incr2<80; incr2++)
		    scr_answ[incr].position[incr2] = 000 ;
/* Initialize the curses windows */
    V_init() ;
/* Display text              */
    for (incr=0; incr<MAX_LINE; incr++)
	move (incr, 0) ;
	addstr(V__.page.line[incr]) ;
/* Display constants   */
    for (at_constant=0; at_constant < V__.NUM_CONST; at_constant++)
	move(V__.constant[at_constant].row, V__.constant[at_constant].col) ;
	switch (V__.constant[at_constant].var_type)
	case 's':
		addstr(V__.constant[at_constant].targetptr.c) ;
		break ;
	case 'i':
		sprintf(temp,"%d", *V__.constant[at_constant].targetptr.i) ;
		addstr (temp) ;
		break ;
	case 'l':
		sprintf(temp,"%ld", *V__.constant[at_constant].targetptr.l) ;
		addstr (temp) ;
		break ;
	case 'f':
		fmt (temp, V__.constant[at_constant].decimal_places,
		    (double)*V__.constant[at_constant].targetptr.f) ;
		addstr (temp) ;
		break ;
	case 'd':
		    (double)*V__.constant[at_constant].targetptr.d) ;
		addstr (temp) ;
		break ;
	default:
		break ;
/* Display answer locations  */
    for (at_answer=0; at_answer < V__.NUM_ANSW; at_answer++)
	/* clear ANSWER */
	for (incr=0; incr<80; incr++)
	    scr_answ[at_answer].position[incr] = 000 ;
	switch (TYPE)
	case 's':
		strcpy(ANSWER, TARGET.c) ;
		RELINE ;
		for (incr=0; incr<LENGTH; incr++)
		    if ( *(TARGET.c + incr) == '\000')
			while (incr++ < LENGTH)
			    addch('_') ;
		    else addch( *(TARGET.c + incr) ) ;
		break ;
	case 'i':
		sprintf(ANSWER,"%d",*TARGET.i) ;
		RELINE ;
		addstr (ANSWER);
		break ;
	case 'l':
		sprintf(ANSWER,"%ld",*TARGET.l) ;
		RELINE ;
		addstr (ANSWER);
		break ;
	case 'f':
		fmt (ANSWER, V__.usr_answ[at_answer].decimal_places, (double)*TARGET.f);
		RELINE ;
		addstr (ANSWER);
		break ;
	case 'd':
		fmt (ANSWER, V__.usr_answ[at_answer].decimal_places, (double)*TARGET.d);
		RELINE ;
		addstr (ANSWER);
		break ;
	default:
		break ;
    num_answers = at_answer ;
    if (interrupts_ok)
	    move(22,0) ;
    else
	    move(23,0) ;
    centered("AFTER COMPLETING ALL ANSWERS, HIT <ESC><ENTER> TO CONTINUE") ;
    if (interrupts_ok)
	sprintf(temp,"(OR <Ctrl-C> TO %s)", V__.interrupt_msg);
	centered(temp);
/* Begin taking commands/answers from terminal */
    at_answer = 0 ;
    ans_col  = 0 ;
    move(ROW, COL) ;
    refresh() ;
    while(1)
	getyx (stdscr, y, x);
	c = getch() & 0177;
	if(c == EOF)
	    move (y, x);
	    refresh();
	    continue;
	if (c == CTRLC && interrupts_ok == 0)
	    move (y, x);
	    refresh();
	    continue;
	if (V__.NUM_ANSW <= 0)
	    if (c == ESC || c == CTRLC)
		interrupts_ok = 0;
		V_exit() ;
		return(c == ESC) ;
	    move (y, x);
	    refresh();
	    continue;
	newchar = c;
	switch (newchar)
	case CR: case NL: case UP: case ESC: case CTRLC:
		V__remove_trail(LENGTH, ANSWER) ;
		switch (TYPE)
		case 's':
			ans_col = (LENGTH) ;
			while((ANSWER[--ans_col] < 041) || (ANSWER[ans_col] > 0175));
			ANSWER[++ans_col] = 000 ;
			strcpy(TARGET.c, ANSWER) ;
			RELINE ;
			addstr(TARGET.c) ;
			break ;
		case 'i':
			*TARGET.i = atoi(ANSWER) ;
			RELINE ;
			sprintf(temp,"%d", *TARGET.i) ;
			addstr (temp) ;
			break ;
		case 'l':
			*TARGET.l = atol(ANSWER) ;
			RELINE ;
			sprintf(temp,"%ld", *TARGET.l) ;
			addstr (temp) ;
			break ;
		case 'f':
			sscanf (ANSWER,"%f",TARGET.f);
			RELINE ;
				(double)*TARGET.f);
			addstr (ANSWER) ;
			break ;
		case 'd':
			sscanf (ANSWER,"%lf",TARGET.d);
			RELINE ;
				(double)*TARGET.d);
			addstr (ANSWER) ;
			break ;
		default:
			break ;
		if ((newchar == CR && lastchar == ESC)|| newchar == CTRLC)
		    interrupts_ok = 0;
		    V_exit() ;
		    return(c == CR) ;
                if (newchar == ESC)
                    lastchar = ESC;
                    break;
		if (newchar == UP)
		    at_answer = (at_answer+num_answers-1) % num_answers ;
		else
		    at_answer = (at_answer+1) % num_answers ;
		ans_col  = 0 ;
		move(ROW, COL) ;
		refresh() ;
		break ;
	case BS:
		ans_col = (ans_col-1 >= 0) ? ans_col-1 : 0 ;
		move(ROW, COL + ans_col) ;
		refresh() ;
		break ;
	case FS:
		if (ANSWER[ans_col+1] != NULL)
		    ans_col = (ans_col+1 <= LENGTH) ? ans_col+1 : LENGTH ;
		    refresh() ;
		else
		    putc(BELL, stderr) ;
		break ;
	case RPLT:
		getyx (stdscr, y, x);		/* shapiro */
		wrefresh(curscr) ;
		move (y, x);		/* shapiro */
		refresh();		/* shapiro */
		break ;
	case DUMP:
		V__dump_window() ;
		break ;
	default:
                if (newchar == 91 && lastchar == ESC) {
                    lastchar = -91;
                    break;
                if (lastchar == -91) {
                    lastchar = 0;
                    if (newchar == 49) {        /* HOME */
		        ans_col = 0 ;
                    } else if (newchar == 52) { /* END */
                        for (c = 0; c < LENGTH && ANSWER[c]; c++) {}
		        ans_col = --c ;
                    } else if (newchar == 65) { /* UP */
		        ans_col  = 0 ;
                    } else if (newchar == 66) { /* DOWN */
		        ans_col  = 0 ;
                    } else if (newchar == 67) { /* LEFT */
		        if (ans_col+1 < LENGTH && ANSWER[ans_col+1]) ++ans_col;
                    } else if (newchar == 68) { /* RIGHT */
                    } else if (newchar == 50) { /* DELETE */
                        break;
		    refresh() ;
                    break;
		if (ans_col >= LENGTH)
		    break ;
		if ((newchar >= '\040') && (newchar < '\176'))
		    addch(newchar) ;
		    ANSWER[ans_col] = newchar ;
		    ans_col++ ;
		    refresh() ;
		break ;
V_intrpt_ok()
    interrupts_ok = 1;		/* will be set false when V_call() exists */
V_intrpt_msg (msg)
    char *msg;
    strcpy (V__.interrupt_msg, msg);
static
fmt(s,n,x)
    char *s;
    double x;
    char buf[20];
    if (n >= 0)
	sprintf (buf, "%%.%dlf", n);
    else
	strcpy (buf, "%.5lf");
/* I had to use .5lf instead of just lf since a number like 65.8 got sprintf'ed as 65.800003
 * this is a hack - I admit it.
    sprintf (s, buf, x);
    if (n < 0)
	V__trim_decimal(s);
static
centered(msg)
    char *msg;
    int indent;
    indent = (80 - strlen(msg))/2;
    while (indent-- > 0)
	addstr(" ");
    addstr(msg);
    addstr("\n");
