Install grass 5 in redhat 6.0
kjell-olav.bjerknes at baerum-kommune.telemax.no kjell-olav.bjerknes at baerum-kommune.telemax.no
Fri Jul 16 02:45:47 EDT 1999
Andrea wrote:
>Where can I find an "install grass 5 how-to"? I'm a novice in linux and I
>have had some difficult to try to install grass 5.
>thank you very much,,
>Andrea
If you have downloaded the source file, you have to make the binaries for your
system. This chrashed on my system (RH5.2) so I downloaded the binaries and
wizz there was I running Grass on my i486. (I haven't checked if there are binaries
for RH6.0 on the ftp but this might be an easy way out of the problem).
If you unzip/untar the file you have downloaded there will be a INSTALL file which
will guide you through the installation. The commands to do this is:
Copy your file to the place where you want to install the program. This is usually
/usr/local
cp grass*.tar.gz /usr/local/grass*.tar.gz
cd /usr/local/
gunzip grass*.tar.gz
tar -xvf grass.tar
When the file is untared you can find the INSTALL file and read this before you
proceed.
Kjell-Olav Bjerknes - student of forestry at the Norwegian
University of Agriculture. Specialising in GIS, Remote Sensing
and Forestry Mapping
mailto: kjbje at nlhstud.nlh.no		 ---> student mail
mailto: kob at baerum-kommune.telemax.no ---> work mail
The be a rock and not to roll
