DXF Import problem
Robert L. Sandefur
RLS at HartCrowser.com
Fri Mar 12 09:11:20 EST 1999
Hi- I have not had the problem in grass but I have had failed dxf imports in other systems and this sometimes will fix import problems
if you have autocad try
reading the dxf
audit and fix any problems (audit is an autocad command)
generate a dxf in autocad
try import into whatever
If you don't get a grass fix this might be worth a shot
Bob Sandefur
>>> Michel Wurtz - LTE <mw at engees.u-strasbg.fr> 03/12/99 02:48AM >>>
I have a DXF file (geologic map) which doesn't import on Grass.
v.in.dxf runs Ok, says 100% done, quit gracefully and...
no file, nada, niet, rien :-((((
I tested the same DXF for import on other GIS (GeoConcept) or
tools (Surfer) and it worked.
This DXF was created with Mapinfo. Any similar experience ?
Is v.in.dxf bugged ? (v.in.dxf3d doesn't give any file, too)
Any helpfull advive will be greatly appreciated !
Michel Wurtz ENGEES - Laboratoire Territoires & Environnement
1, quai Koch - BP 1039, F-67070 STRASBOURG cedex
Tel: +33 03.88.24.82.45 Fax: +33 03.88.37.04.97
