Compiling Errors
Bill Hughes
bhughes at grasshoppernet.com
Thu Mar 18 19:35:52 EST 1999
On Thu, 18 Mar 1999 at 15:23:18 +0100 (MET) Agustin Lobo wrote:
> 1. Do we need the Motif include files? I'm not able to
> find the directory.
No.
> 2. X library: we have:
/usr/X11R6/lib
> 3. We get warnings with the math lib:
> I answered "n" as these were just Warnings, correct?
"n" is fine. The math library checker needs to #include <math.h>
but it doesn't. It also doesn't use pow() correctly, so maybe
it's best that it doesn't know any better.
> 4. TERMLIB:
> 5. Same thing for curses:
> CURSES [-lcurses] :
You probably have libncurses, instead. Try '-lncurses'
> 6. Should we use gcc or cc?
There is probably no difference between them.
> 7. How was the command to run GISGEN and get the output bith to the
> terminal and to a file? (We are using bash, by the way, is it
> better than csh?).
./GISGEN.alpha | tee 2>&1 > errorfile
(./GISGEN.alpha > errorfile 2>&1 &); tail -f errorfile
No opinions on bash/csh.
Bill Hughes
