avhrr level 1b data from saa, how to unpack?
Agustin Lobo
alobo at ija.csic.es
Sat Mar 20 08:46:43 EST 1999
I'll look into it, but why are you not using
the Sharp format? Where are your data coming from?
Regarding your subject, you should look into
http://www.mtv.sai.jrc.it/projects/fire/home.html
and/or contact
E-mail: Jean-Marie.Gregoire at jrc.it
Agus
****NOTE NEW PHONE NUMBER*****
Dr. Agustin Lobo
Instituto de Ciencias de la Tierra (CSIC)
Lluis Sole Sabaris s/n
08028 Barcelona SPAIN
tel 34 93409 5410
fax 34 93411 0012
http://pangea.ija.csic.es/alobo
On Fri, 19 Mar 1999, Alexander Brauns wrote:
> does anyone have a hint on how to unpack avhrr hrpt data from noaa
> satellite active archive (SAA)? the data is provided via ftp in 8 or
> 10bit format, but the files are packed in some obscure way, the relevant
> documentation (POD-polar orbital data guide) does only provide a fortran
> routine for unpacking, I wonder if anyone already has a solution to this?
> the images are intended for wildfire monitoring in northern guatemala
> help would be appreciated
> victor hugo ramos, alexander brauns
> centro de monitoreo y informacion - cemec -
> conap region VIII, peten, guatemala
> tel +502-9260809
> fax +502-9260812
> e-mail: conappro at quetzal.net
