grass5.0b fifo.1a not available
    Bernhard Reiter
    bernhard at uwm.edu
    Sun Mar 28 12:15:12 EST 1999
On Sun, Mar 28, 1999 at 07:07:13PM +0700, Vitaliy Ababiy wrote:
> But my /usr/local/grass5.0beta/dev/
> have not any files.
> what is fifo.1a?
fifo stands for   first in first out
and means a special file which can be used as a pipe
between two programs. In this case the grass command and the X11
window displaying program.
> Is it devise from my main UNIX dir?
> /dev/-tty ?
It has nothing to do with your unix /dev devices.
I found the problem, that somewhere in the compilation and installation
the path to the "mknod" command is hardcoded.
Deleting the path from that command in generic/GISGEN.sh
might help to get the fifos created.
Watch the beginning of that normal compilation script to see the
messages about creting the fifos.
Hope that helps,
	Bernhard
Name: not available
Desc: not available
Url : http://lists.osgeo.org/pipermail/grass-user/attachments/19990328/0cb0d90a/attachment.bin
