label <-> category value
Malcolm Williamson
malcolm at cast.uark.edu
Fri May 7 16:30:48 EDT 1999
Hi Dieter
This is quite simple. Take the category file ("cats" directory) and use
your favorite editor to turn it into a rules file for r.reclass.
1:4 becomes 1 = 4
2:7 2 = 7
3:4 3 = 4
etc.
Then,
r.reclass i=old_map o=new_map < rules_file
Regards,
-Malcolm Williamson
On Wed, 5 May 1999, DIETER LEHMANN wrote:
> Hello,
> I need to change the category-value with the label after importing a
> Arc/Info polygon coverage with m.in.e00.
> Thanks.
> Dieter
> _____________________________________
> Dieter Lehmann
> State University of applied Sciences
> Schelmenwasen 4-8
> D-72622 Nuertingen, Germany
> lehmann at fh-nuertingen.de
> Phone: +49 (0) 7022 404 Ext. 192 or Ext. 152
> Fax: +49 (0) 7022 404 Ext. 166
