grass 5.0 beta configure/make
Roderick A. Anderson raanders at altoplanos.net
Mon Nov 1 15:04:59 EST 1999
On Mon, 1 Nov 1999, Eric Mitchell wrote:
> I downloaded the new beta4 source release, and attempted a
> "configure ; make ; make install", but performing "make"
> in the top level source directory does nothing.  Is the
> autoconf build process complete yet? Is anyone working on
I ran into the same problem this weekend.  I looks like there needs to be
a bit more thought put into the process.  I'm not too familiar with 'make'
(just use it) so my observations could be flawed.  There appears to be
semi-colons missing between each of the commands on the lines in
'Makefile'.  I tried running each line by hand but ran out of patience and
wetwear memory with all the substitutions.  I'll have another look tonight
since it needs to be done with make to create a rpm file.
   Any good online tutorials on make around?
Rod
raanders at altoplanos.net               Altoplanos Information Systems, Inc.
Voice: 208.765.6149                            212 S. 11th Street, Suite 5
FAX: 208.664.5299                                  Coeur d'Alene, ID 83814
