Compiling NVIZ2.2
Kurt Gerber kurt.gerber at datacomm.ch
Sun Oct 3 13:15:21 EDT 1999
Hi Michael
The Problem is solved! I compiled Nviz2.2 successfully. The Problem was: I
symlinked only tk.h, but of course I had to do the same thing with tcl.h.
Thanks for your help!
Kurt
On Sat, 02 Oct 1999, you wrote:
>Hi Kurt !
>Right now i am not at the computer where i installed nviz. But you are
>right: i forgot to say, that i added (now i am not sure, where) a
>include<tk.h> somewhere. I suppose it was in tkAppInit.c (not sure).
>I will write you again when i have looked it up at work.
>Cheers, Michael
>Michael Schulz
>Christoph-Mang-Str.5       Geologisches Institut
>79100 Freiburg             Universitaet Freiburg
>                           Albertstr. 23b
>                           79104 Freiburg
>On Fri, 1 Oct 1999, Kurt Gerber wrote:
>> Hi
>> I tried with your suggestion. I symlinked tk8.0.h with tk.h. But it didn't
>> work.
>> I've got the following error message:
>> 5.0beta/src/include  -c tkAppInit.c
>> In file included from tkAppInit.c:7:
>> /usr/X11R6/include/tk.h:1275: parse error before `Tcl_Obj'
>> /usr/X11R6/include/tk.h:1468: parse error before `Tcl_Obj'
>> /usr/X11R6/include/tk.h:1495: parse error before `Tcl_Obj'
>> /usr/X11R6/include/tk.h:1542: parse error before `Tcl_Obj'
>> /usr/X11R6/include/tk.h:1551: parse error before `Tcl_Obj'
>> In file included from togl.h:19,
>>                  from tkAppInit.c:8:
>> tkInt.h:800: parse error before `Tcl_Obj'
>> make[1]: *** [OBJ.i686-linux-elf/tkAppInit.o] Error 1
>> make[1]: Leaving directory `/usr/src/grass5.0beta/src.contrib/GMSL/NVIZ2.2/src'
>> make: *** [nvwish] Error 2
>> Cheers, Kurt
>> On Fri, 01 Oct 1999, Michael Schulz wrote:
>> >Hello Kurt !
>> >I had the same problem when compiling Nviz on Suse. "Tk_SafeInit" is
>> >declared in tk8.0.h, but after installing the tcl/tk-Stuff with Suse, you
>> >still have "old" tk.h and tcl.h (version 7.x). I symlinked the "new"
>> >tk8.0.h to tk.h and backuped the "old" tk.h !
>> >This worked for me! Perhaps it can help to fix your probelm !
>> >Cheers, Michael
>> >Michael Schulz
>> >                           Albertstr. 23b
>> >                           79104 Freiburg
>> >On Thu, 30 Sep 1999, Kurt Gerber wrote:
>> >> Hi everybody
>> >> After compiling grass5.0beta3 on SuSE 6.0 and Linux 2.2.9, I tried to compile
>> >> NVIZ2.2.
>> >> It stopped with the following error:
>> >>                  from tkAppInit.c:8:
>> >> tkAppInit.c: In function `Tcl_AppInit':
>> >> tkAppInit.c:73: `Tk_SafeInit' undeclared (first use in this function)tkAppInit.c:73: (Each undeclared identifier is reported only once
>> >> tkAppInit.c:73: for each function it appears in.)
>> >> It doesn't make sense to me, but because there is something with Tcl/tk in the
>> >> Error Message, I installed a newer version of Tcl/Tk. I had version 8.04 and
>> >> now I have 8.05 but compiling is still not working.
>> >> Kurt Gerber
