configure error
Agustin Lobo alobo at ija.csic.es
Tue Oct 5 10:37:14 EDT 1999
As far as I can tell this problem was only present in
the distribution from www.geog.uni-hannover.de. I have
downloaded the file grass5.0beta3g.tar from
www.baylor.edu and there is no problem.
(BTW: it's odd that the beta3 be on a directory
named grass5.0beta2)
Agus
Dr. Agustin Lobo
Instituto de Ciencias de la Tierra (CSIC)
Lluis Sole Sabaris s/n
08028 Barcelona SPAIN
tel 34 93409 5410
fax 34 93411 0012
http://pangea.ija.csic.es/alobo
On Mon, 4 Oct 1999, Agustin Lobo wrote:
> When I try to compile grass5.0beta3 on
> a SuSe 6.2 box, all I get is:
> silvestre:/usr/local/grass5.0beta # ./configure
> loading cache ./config.cache
> checking host system type... i686-linux-elf
> checking for gcc... gcc
> ./configure: line 625: syntax error near unexpected token `"(c'
> ./configure: line 625: `  echo $ac_n "(cached) $ac_c" 1>&6'
> Is this a problem of the configuration program?
> Agus
> Dr. Agustin Lobo
> tel 34 93409 5410
> fax 34 93411 0012
