r.in.hdf: wrong in grass5beta3
Agustin Lobo
alobo at ija.csic.es
Fri Oct 8 12:18:58 EDT 1999
Thanks, at least we know where the problem is.
Agus
Dr. Agustin Lobo
Instituto de Ciencias de la Tierra (CSIC)
Lluis Sole Sabaris s/n
08028 Barcelona SPAIN
tel 34 93409 5410
fax 34 93411 0012
http://pangea.ija.csic.es/alobo
On Fri, 8 Oct 1999, Markus Neteler wrote:
> > I've used r.in.hdf to import an image
> > from the VEGETATION instrument of
> > SPOT4, which come in hdf.
> > The program runs, but the resulting raster:
> > 1. Has correct size.
> > 2. The image is divided in 4 quarters:
> > - A 4x inverse zoom appears in the 2 upper quarters
> > - Blank in the 2 bottom quarters.
> Hi Agus,
> currently I am updating r.in.hdf/r.out.hdf to HDF4.1.3 lib
> (the latest). It is not ready yet, sorry. The results from
> your file are the same here: The image is divided in 4 quarters.
> Perhaps it will be fixes with the new HDF-lib.
> Best regards
> Markus
