grass5b3 install problem
jiao weili
wljiao at ne.rsgs.ac.cn
Thu Oct 14 00:30:00 EDT 1999
>jiao weili wrote:
>> Hi,
>> I downloaded grass5.0beta3 and try to compile it. I got failed at:
src/display/d.3d.
>> The error message as
>> In function 'V_call':
>> Vcall.c:150/160/168/178/... undefined reference to "__waddbytes".
>> The same error also appears at src/display/d.color.
>The problem is related to your curses package. I run Linux 2.0.30
>(slackware distribution) and had the same problem. It appears that
>the "curses.h" include file is not the one needed for ncurses library.
>The workaround I used was to move all the files from
>/usr/include/ncurses
>to /usr/include (file with same name in /usr/include were renamed
>from xxx.h to OLDxxx.h)
I did this, but still have the same problem. I run redhat linux 5.2.
>I hope this can solve your problem.
>Michel Wurtz ENGEES - CEREG
> 1, quai Koch - BP 1039, F-67070 STRASBOURG cedex
> Tel: +33 03.88.24.82.45 Fax: +33 03.88.37.04.97
jiao weili
