to different users of GRASS
Hector Villalobos
hvillal at balandra.uabcs.mx
Fri Oct 15 21:25:27 EDT 1999
> It failed to open after installation is over. There were 20 lines of
> error message like this
> /usr/local/grass5/dev/create_fifos_new.sh: /usr/local/grass5.0b
> /dev/fifo.19b: No such file or directory
> But in dev directory create_fifos.sh and create_fifos_new.sh
> files are existing.
Concerning your first question, you must edit the appropriate lines
in the create_fifos_new.sh file to point to the directory where grass
was installed. After that you should run the edited file to create the
fifos:
sh create_fifos_new.sh
Good luck
Hector Villalobos
<hvillal at ipn9021.ipn.mx> <hvillal at balandra.uabcs.mx>
Depto. de Pesquerias y Biologia Marina
CICIMAR-IPN
