Tangential Topic - Hand held GPS units
Roderick A. Anderson
raanders at altoplanos.net
Fri Oct 22 10:00:22 EDT 1999
On Fri, 22 Oct 1999, Rich Shepard wrote:
> There are several considerations in choosing a GPS for collecting data
> which will be used in a GIS. I spent the first two days of this week on a
> refresher course which came with the purchase of my new, high-precision GPS
> receiver.
[SNIP]
> Well, end of monograph. My point is to educate about the uses of different
> GPS receivers. You can believe me when I write that if I could get the same
> accuracy and functionality from a $500 GPS receiver, I would not have spent
> almost $10,000 on one.
As I understand. I worked Land Surveys (Cadastral) for ten years. This
GPS was for recreational use. It just didn't have the displayable map
detail I needed.
As an aside this could be a promising business. Here in North Idaho
while surveying I've got turned around several times and would have loved
a handheld GPS unit with the current areas QUAD on the display. The brush
gets so thick on some of the hill sides you can walk right by a road and
never know it was there.
Custom maps for 'recreational' GPS units!
Rod
raanders at altoplanos.net Altoplanos Information Systems, Inc.
Voice: 208.765.6149 212 S. 11th Street, Suite 5
FAX: 208.664.5299 Coeur d'Alene, ID 83814
