Announce: new GRASS 5 beta4 on Tuesday, 26. October
    Luca Palmeri
    lpalmeri at ux1.unipd.it
    Tue Oct 26 09:29:49 EDT 1999
Thank you Markus,
        I am very glad also that GRASS is now copyleft.
        I have compiled it right now, and things go pretty well. On my
Linux system only two major
stops in m.proj and NVIZ.
Following you'll find the report and my fixes. Now I'll turn to the
64bit lane.
cheers
LP
GRASS 5.0beta41
                     P R O B L E M S    I N   C O M P I L A T I O N
26/Oct/1999       Luca Palmeri   (lpalmeri at ux1.unipd.it)
Linux RedHat 6.0, kernel 2.2.5-15 on a i586
Toshiba satellite 2540CDT
/usr/local/grass5b2/src/src/misc/m.proj
  make -f OBJ.i586-linux-elf/make.rules
make[1]: Entering directory `/usr/local/grass5b2/src/src/misc/m.proj'
In file included from main.c:9:
local_proto.h:10: redefinition of `null'
geo.h:60: `null' previously defined here
local_proto.h:41: conflicting types for `get_LL_stuff'
geo.h:90: previous declaration of `get_LL_stuff'
local_proto.h:54: conflicting types for `process'
geo.h:103: previous declaration of `process'
GISGEN failure at STEP: src/misc/m.proj
make: *** [do-install] Error 1
---> fix: remove the file src/m.proj/geo.h (or rename it), the right one
is
             already found in src/include/.
NVIZ 2.2
 Unresolved symbols dlerror, dlopen .....
---> fix: add the linker directive -ldl in src/Gmakefile line 16
"OGL_LIB=...."
xganim
 doesn't compile because it complains doesn't find Xm.h ......
---> fix: Install Motif, or Lesstif (recomended -->
http://www.lesstif.org), or simply
             comment the xganim line in the file src/CMD/lists/GRASS,
and restart compilation.
########################### AND THAT IS ALL ............................
BRAVO MARKUS
Markus Neteler wrote:
> Hi there!
> GRASS 5 beta4 is published under GPL:
> http://www.geog.uni-hannover.de/grass/
> The new Baylor server shall follow soon (I hope today).
> Cheers
>  Markus Neteler
--> Luca Palmeri - Dip. Proc. Chimici dell'Ingengeria
    Universita' di Padova  TEL: +390498275527 -------
-------------------------  FAX: +390498275528 -------
--> Think holistic @ the end of the 2nd millenium <--
