GRASS 5 beta4 on DU alpha
    Bernhard Reiter
    bernhard at uwm.edu
    Wed Oct 27 22:04:15 EDT 1999
On Tue, Oct 26, 1999 at 09:07:11PM +0200, Luca Palmeri wrote:
> Hi Bernhard,
> Bernhard Reiter wrote:
> > > 0) Changed "gcc" -> "cc" and "-g" -> "-g3" in src/CMD/head/head
> > >    cc likes very much the -g3 optimization with debugging symbols
> > But this is not necessary.
> > And usually you can give options to configure, like
> >         CC=cc CFLAGS="-std1 -O -g3"  ./configure .....
> Yes, sorry it is a little bit inelegant, but I did like that just to see
> what where the guess of ./configure on CC and related options.
> What you mean by unecessary ?
Oh that you can give it to ./configure as I showed above.
> Yes in fact, but I do not have a libcurses.so
> Is that necessary to use ncurses ? I think so, I am not sure
> but anyway I didn't find any other way to compile.
It should work without ncurses, IMO.
The compile is running, because
I had  "-std1 -w0" flags given, I get a bit more error msgs.
	Bernhard
Research Assistant, Geog Dept UM-Milwaukee, USA.    (www.uwm.edu/~bernhard)
Free Software Projects and Consulting 			    (intevation.de)
Association for a Free Informational Infrastructure              (ffii.org)
Name: not available
Desc: not available
Url : http://lists.osgeo.org/pipermail/grass-user/attachments/19991027/6884a278/attachment.bin
