NVIZ2.2
Markus Neteler neteler at geog.uni-hannover.de
Wed Sep 15 13:49:58 EDT 1999
> This question is for those that are using NVIZ.
> When I select the surface panel and then click on the
> NEW button in order to add a new layer, and then click again
> on new from the surface attribute window, I have a window that
> very likely should give me a list of available mapsets and
> raster files. Instead the window is empty no mapset, no raster.
> (My g.gisenv gives mapset=PERMANENT location=adibacc).
> Moreover if I type in the window the name of an existing raster
> (for example elev_tps my DEM) and then click on accept, everything
> goes well and I have my wanderfull 3D elevation map displayed.
> Does anybody have any suggestions about that or have encountered
> the same problem.
> cheers
> LP
Hi Luca,
I have the same problem. BUT: If you enter the name of a map
directly, it is accepted. So there is a bug in displaying the
map's names. [how to fix that?]
Greetings
  Markus
