Vector attributes
David D Gray ddgray at armadce.demon.co.uk
Mon Apr 3 09:00:34 EDT 2000
spijker at geo.uu.nl wrote:
> I'm creating a program that creates vector areas. When such an area is
> written to disk  with 'Vect_write_line(map,AREA,pnts)' I also want to give
> that area an attribute. The problem is that I don't know how to achieve
> this. Is there a function to create attributes or can I give the area
> attribute to vect_write_line? The Grass Programming Guide wasn't very
> clear on this (or I missed it ;-)
> Grtz, Job
Hi
I have been working on similar tasks recently with shapefile
import.
I don't think there is a particular function for this. You must create a
dig_att file with G_fopen_new, or open an already existing with
G_fopen_append. Then a line like
fprintf( attribute_file, "L  %-12f  %-12f  %-8d \n",
         x_co_ordinate, y_co_ordinate, some_int_attribute );
writes the line. It will look something like
L  123456.876543  919828.477583  13
in an ascii file of the map's name under ${MAPSET}/dig_att
The problem is - you must assign a label point to the polygon,
which must be on the interior of the polygon (but outside any
islands the polygon might have). This is far from trivial
to work out in the general case. But depending on the way you
are building polygons you might the advantage of information that
allows you to assign a suitable point.
Hope this helps
David
