can not allocate any read/write color cells
Markus Neteler
neteler at geog.uni-hannover.de
Wed Apr 12 12:13:03 EDT 2000
Hi Horacio,
as you write: you still have 8 bit color depth. So it
is no surprise that there is no problem solution (even
with new hardware!).
As mentioned in another mail you have to tell you
X-server to run in 15/16/24 bit (as you like).
Now it is just a small software configuration problem.
Use .xserverrc to adjust the depth. Here you find some
hints:
http://www.geog.uni-hannover.de/grass/faq/allocate_colorcell.html
Then it will work (it is not a GRASS problem but a X-configuration
problem).
Best wishes
Markus
On Wed, Apr 12, 2000 at 11:00:23AM -0400, Horacio wrote:
> Markus Neteler wrote:
> > Hi,
> > to check the current settings of your video
> > card
> > - start X
> > - run: xdpyinfo
> > Please tell me what you get (especially "color depth").
> > Note: Today I have put an XDRIVER update in CVS (for GRASS 5 beta7)
> > written by Carl Anderson. He updated to run the XDRIVER
> > on various platforms with various color depth without
> > problems!
> > On Tue, Apr 11, 2000 at 06:22:06PM -0400, Horacio wrote:
> > > I just upgraded my video card + monitor but can't get to display any
> > > graphic in grass...
> > > I get the following error:
> > > GRASS: > d.mon start=x0
> > > I'm sure that it is a very simple thing about the card setting or
> > > somthing... can somebody tell me what i should do to get the display
> > > work?
> > > I'll appreciate any help.... and will sum.
> > > Thanks,
> Hi Markus,
> This is the tail of the xdpyinfo... it seems that i have 8 depth
> Any thought?
> Thanks in advance...
> Horacio
> +++++++++++++++xpdyinfo.output+++++++++++++++
> screen #0:
> dimensions: 1280x1024 pixels (433x347 millimeters)
> resolution: 75x75 dots per inch
> depths (2): 1, 8
> root window id: 0x2a
> depth of root window: 8 planes
> number of colormaps: minimum 1, maximum 1
> default colormap: 0x21
> default number of colormap cells: 256
> preallocated pixels: black 0, white 1
> options: backing-store YES, save-unders YES
> largest cursor: 64x64
> current input event mask: 0x58207f
> KeyPressMask KeyReleaseMask ButtonPressMask
> ButtonReleaseMask EnterWindowMask LeaveWindowMask
> PointerMotionMask ButtonMotionMask
> SubstructureNotifyMask
> SubstructureRedirectMask PropertyChangeMask
> number of visuals: 6
> default visual id: 0x22
> visual:
> visual id: 0x22
> class: PseudoColor
> depth: 8 planes
> available colormap entries: 256
> red, green, blue masks: 0x0, 0x0, 0x0
> significant bits in color specification: 6 bits
> visual:
> visual id: 0x23
> class: DirectColor
> depth: 8 planes
> available colormap entries: 8 per subfield
> red, green, blue masks: 0x7, 0x38, 0xc0
> visual:
> visual id: 0x24
> class: GrayScale
> depth: 8 planes
> visual:
> visual id: 0x25
> class: StaticColor
> depth: 8 planes
Dipl.-Geogr. Markus Neteler * University of Hannover
Institute of Physical Geography and Landscape Ecology
Schneiderberg 50 * D-30167 Hannover * Germany
Tel: ++49-(0)511-762-4494 Fax: -3984
