ps.map questions
Radim Blazek
Radim.Blazek at dhv.cz
Thu Apr 13 07:19:39 EDT 2000
Rich Shepard wrote:
> 1) Where can I specify the paper size for the map? For example, my HP
Papers are defined in $GISBASE/etc/paint/psdevices as 'devices' and selected by ps.select
> 2) What do folks do for a north arrow? If someone has a collection, is it
You can create any picture in .ps format and use 'psfile' option to include to output.
( I would like add option 'epsfile' which could specify also also position,
scale and rotation sometimes)
Markus Neteler wrote:
> please read additional ps.map.new.html:
Is old. Up to date html man is attached and man should be under CVS
(could Markus Neteler replace it on Web by new one)
> - cwidth > plotted line width = cwidth * category
> label label for map - for legend labels of vectors
And:
'ref' for vector line ( justification, fill appendixes of line) and
'labels' reads ROTATE: from paint/labels/file.
+ probably twice as many bugs =>
> Suggestion:
> - remove p.map
> - remove ps.map.old
> Rename p.map.new to p.map
> Rename ps.map.new to ps.map
ps.map.new is not tested enough now and we should add more options. Therefore
I think that it is not time to replace ps.map.old (ps.map) by ps.map.new.
It could cause problems. I expect ps.map.new to be module with more options
but buggy for few months.
Request for help:
offset, coffset and ref are marked as experimental in man because I could not find
any free function for creating PARALLEL LINE in distance and I do not know how to write it
better than it is now. Do anybody know about such function freely available.
Radim
URL: http://lists.osgeo.org/pipermail/grass-user/attachments/20000413/f3b3b744/ps.map.new.html
