ellipsoid Krasovsky
Elke Friebe
E.Friebe at t-online.de
Mon Apr 17 14:05:28 EDT 2000
Hallo,
thank you very much Andreas for your mail. It helped me for the first
step,
but there is the second: to get this dates together with other data.
I know, there is the modul r.proj.
I did the steps as they are described on the help manual. But after
minutes
of working the program creates an empty file.
Perhaps it has something to do with the Grid-Resolution: of the KVR-1000
satellite picture: 3.09302918. I set the Grid-Resolution af both
locations
(source location and the current location) on this Grid-Resolution.
I tested two variants with resolution value on r.proj:
3.09302918 and Default (calculated from the number of cols in input
map).
both with the same result: empty file.
Is there somebody with a good idea?
My aim is to make an image fusion. Is it at all possible to make an
fusion with TM picture and KVR-1000 (30 m and 3.09302918
Grid-Resolution)???
Many Greetings
Elke
P.S:
I worked with GRASS 5.0 Beta 3
The KVR-1000 pictue is a file with about 25 MB.
Andreas Lange schrieb:
> Elke Friebe wrote:
> > Hallo GRASSER,
> > is there somebody who has already worked with ellipsoid Krasovsky (
> > russian Satellite picture KVR1000) ?
> > Any help greatly appreciated...
> > Elke Friebe
> > (KVR-1000 georeferenced - ellipsoid Krasovsky, projection Gauss-Kruger,
> > central
> > meridian 11*E)
> Hi Elke,
> what is your question here? I am no specialist in this, so you should
> verify my suggestions.
> The ellipsoid Krasovsky is supported by grass (see file
> etc/ellipse.table). This is the same as the old topographic maps from
> DDR, projection Gauss-Krueger is the same as in germany. Central
> meridian 11E is different from the system used by the german
> gauss-krueger-system, which uses 6E, 9E, 12E and 15E (2, 3, 4, and 5) as
> central meridians. But this should be no problem as far as you do not
> need to import other data in your location.
> Use this values for your location:
> Projection: tmerc, Ellipsoid: krasovsky, Central Parallel 0N, Central
> Meridian 11E, Scale Factor at Central Meridian: 1, False Easting 50 000,
> Plural Form of units: meters.
> HTH,
> Gruesse,
> Andreas
> Andreas Lange, 65187 Wiesbaden, Germany, Tel. +49 611 807850
> Andreas.Lange at Rhein-Main.de, A.C.Lange at GMX.net
