New problem compiling grass5.0beta7
Eric G . Miller
egm2 at jps.net
Mon Apr 24 22:31:17 EDT 2000
On Mon, Apr 24, 2000 at 04:39:22PM -0700, Rich Shepard wrote:
> On Mon, 24 Apr 2000, Skip wrote:
> > gcc -g -O2 -I/usr/local/grass5.0beta/src/include -c lex.c
> > binfer.l:41: redefinition of `yylineno'
> > lex.c:271: `yylineno' previously defined here
> > make[1]: *** [OBJ.i686-linux-elf/lex.o] Error 1
> > make[1]: Leaving directory `/usr/local/grass5.0beta/src/raster/r.binfer'
> > GISGEN failure at STEP: src/raster/r.binfer
> > make: *** [do-install] Error 1
> Skip,
> This came up within the past fortnight. I don't remember the solution, but
> there is a simple one.
Replace /usr/bin/lex (which should be a symlink to /usr/bin/flex), with
a shell script that calls flex with the '-l' option.
#/bin/sh
# Compatibility mode... lex-flex
flex -l $*
Make sure to chmod +x the script. Note: I'm not a programmer, but I play
one on mailing lists! Caveat Emptor!
¶ One·should·only·use·the·ASCII·characterset·when·compos
» ing·email·messages.
