Hi everyone. Just a quick point to add to Markus' earlier announcement about CVS updates. The best results are obtained with the v.in.shape if you run `v.spag -i' on the output. It seems that v.support generates many duplicate lines. This is now pretty functional and should import most `clean' files without error David
