LANDSAT TM
Elke Friebe E.Friebe at T-Online.de
Tue Aug 8 14:39:25 EDT 2000
Hi Rohit,
if you have the possibility to switch your bands into ASCII-files it is
no problem with "r.in.arc "
for example: input=band1.asc output=band1
greetings
Elke
Rohit schrieb:
> Greetings,
> I am a grass user, and i am developing a web based interface to grass
> using CORBA under GPL.
> The ultimate objective is to allow the web based java applet [similar to
> the grass client] to be able to access a distributed grass database.
> Your suggestions/advice is welcome at nadig at web.cs.ndsu.nodak.edu
> I also have another question regarding importing LANDSAT TM images into a
> grass database. does anyone know how to import TM images in the BSQ
> format?
> The i.tape.other and i.tape.tm would work only for tape devices?
> thank you,
> Rohit
