compile error with 4.3 on Linuxppc
Bernhard Reiter
bernhard at intevation.de
Sat Aug 12 11:50:46 EDT 2000
Do you have "make" installed? Is is in the path?
(Okay, simple question, but you never know.)
Try to add a "-x" to the gmake4.3 shell call to see what is actually
going on.
AFAIK compilation of 4.3 of LinuxPPC did not work out of the box,
because of other errors. You could give the grass5.0beta6 a try,
there is an rpm for linuxppc2000 on the freegis.org development ftp
site.
Bernhard
On Fri, Aug 11, 2000 at 06:21:38PM -0400, R. Joe Brandon wrote:
> While compiling Grass4.3 on LinuxPPC I ran into the following error when
> I executed the command
> GISGEN.my
> GISGEN failure at STEP: man
> At the command line the error showed as:
> /usr/local/grass43/src43/gmake4.3: make command not found
Professional Service around Free Software (intevation.net)
The FreeGIS Project (freegis.org)
Association for a Free Informational Infrastructure (ffii.org)
Name: not available
Desc: not available
Url : http://lists.osgeo.org/pipermail/grass-user/attachments/20000812/e3029b5b/attachment.bin
