Projections request...
Morten Hulden
morten at ngb.se
Mon Aug 14 06:06:28 EDT 2000
Hi Eric,
you can add support for false easting&northing for Alber's Equal Area in
GRASS5beta by editing the file src/libes/gis/geo_init.c. On line 35, just
after the last TABLE[AEA] definition, add the following lines:
TABLE[AEA][X0].ask = 1;
TABLE[AEA][X0].def_exists = 1;
TABLE[AEA][X0].deflt = 0.0;
TABLE[AEA][Y0].ask = 1;
TABLE[AEA][Y0].def_exists = 1;
TABLE[AEA][Y0].deflt = 0.0;
Then recompile.
regards
Morten Hulden
On Sun, 13 Aug 2000, Eric G . Miller wrote:
> Several months ago, I asked about False Northing/Eastings for the Albers
> Equal Area Projection. GRASS currently doesn't allow the specification
> of these items for this projection. Recently I was contacted by another
> person who read my previous posting about this subject -- wondering if I
> had a solution.
> Anyway, a number of state agencies in California have standardised on an
> Albers Equal Area Projection that has a false northing. There is quite
> a bit of data available in this projection. Unfortunately, there's no
> clean way to get this data into GRASS at the moment. I know the proj4
> library supports this feature; so, I'm wondering if it would be possible
> to implement it? I've been searching through the GRASS code base, but
> am not familiar enough with it to know how all the projection code ties
> together. I know there are many other things on the TODO list, but
> perhaps someone familiar with the projection code could point me in the
> right direction(s)?
> Thanks.
