beta8 compilation problem
    Malcolm Williamson
    malcolm at cast.uark.edu
    Wed Aug 23 00:24:33 EDT 2000
I'm probably overlooking something silly, but I'm having no luck getting
the latest version to compile under either Solaris 2.6 or 2.5. After
running ./configure with user-owned directories defined, I run
make install
and get the following:
malcolm at cast 32%>>make install
test -d /proj/grass4.1/grass5.0 || mkdir -p -m 755
test -d src/CMD/next_step || mkdir -p src/CMD/next_step
UNIX_BIN=/home/malcolm SRC=`pwd` MAKE=make NAME_VER=`cat src/CMD/VERSION
| head
-1 | sed 's/\..*//'` GISBASE=/proj/grass4.1/grass5.0 MACHINENAME=`uname
-n` /bin/sh src/CMD/generic/CREATE_GMAKE.sh
sh: test: argument expected
*** Error code 1
make: Fatal error: Command failed for target `pre-install'
Any ideas? Much obliged,
	-Malcolm Williamson
	 CAST - University of Arkansas
