[GRASSLIST:1277] Re: tcltk problem with grass5b10
William L. Baker
BakerWL at uwyo.edu
Thu Dec 14 12:01:16 EST 2000
I'm guessing that because the tcl script associated with
GRASS startup does not run properly that the .grassrc
file that is supposed to contain the GISDBASE info
simply doesn't get made right or read right. If you
fix the reference to the tcl library, then redo make
install, in my case this fixed it.
Bill B.
-----Original Message-----
Sent: Thursday, December 14, 2000 6:49 AM
To: grasslist at baylor.edu
Subject: [GRASSLIST:1274] Re: tcltk problem with grass5b10
"William L. Baker" wrote:
> I too had this same error upon installing under Linux
> Mandrake 7.2. ./configure fails to find the tcl library
> (tcltk 8.3 is included) for some reason. After manually
> editing the resulting Gmakefile so that the library is
> correctly identified, then the make install step does
> work and the funny little box etc. go away. Perhaps
> there's a way to fix the configure script so it finds
> the library right in the future? This is beyond my
> area of knowledge.
> Bill B
I have the same problem, but when I close the box I have a null
parameter error
in the Init.sh: GISDBASE not set.
Peter
