NVIZ Segmentation Fault
Markus Neteler
neteler at geog.uni-hannover.de
Fri Feb 25 05:17:49 EST 2000
Hi there,
> > My
> >last strace on NVIZ seemed to indicate it fails shortly after loading
> >the tk.tcl interface. It appears to send an inappropriate IO request:
> >access("/usr/lib/tk8.0/tk.tcl", F_OK) = 0
> >stat("/usr/lib/tk8.0/tk.tcl", {st_mode=S_IFREG|0644, st_size=5697, ...})
> >= 0
> >open("/usr/lib/tk8.0/tk.tcl", O_RDONLY) = 7
> >fcntl(7, F_SETFD, FD_CLOEXEC) = 0
> >ioctl(7, TCGETS, 0xbfffd8c8) = -1 ENOTTY (Inappropriate ioctl
> >for device)
> >read(7, "# tk.tcl --\n#\n# Initialization s"..., 4096) = 4096
> >read(7, "vent add <<Clear>> <Clear>\n }"..., 4096) = 1601
> >close(7) = 0
> >--- SIGSEGV (Segmentation fault) ---
> >+++ killed by SIGSEGV +++
> This is also good to see - an strace on my machine looks pretty close to
> identical. I guess I need to recompile and look for any suspect messages.
> >I wonder if ENOTTY has any relation to UNIX 98 PTYs? Just speculatin'...
> Hopefully there is an NVIZ person out there who may recognize where this is
> happening.
I am still searching for someone with programming knowledge to
fix this :-)
What I found here:
The GNU C Library
http://gnu.senet.com.au/glibc/libc_2.html
Macro: int ENOTTY
Inappropriate I/O control operation, such as trying to set terminal
modes on an ordinary file.
Maybe this is useful to somebody. Could it be a wrong
sprintf, fprintf call somewhere in
src.contrib/GMSL/NVIZ2.2/src/
Note: On some Linux boxes it works (luckily on my system).
Regards
Markus Neteler
