GRASS on WIN/Cygnus forthcoming
Angus Carr
acarr at iname.com
Thu Jan 13 09:08:55 EST 2000
Which revision of the GRASS code are you currently using?
I would be interested, since I am porting the message queues into the
current Grass 5 tree, including the curent 24-bit XDRIVER.
The port isn't terribly difficult, but I am encountering the whole
problem of porting changes to a codebase that has since changed...
I am using the 1994 version of the changed files, as posted to moon at
the time. If you've made any changes since then, I would appreciate the
patch, or the whole file. I am especially interested by the double
d.erase bug.
By the way, thanks for doing it in the first place.
Angus Carr.
Ronald Wiemer wrote:
> I was the one that programmed the Message Queue stuff. In fact I am still using it, since I made some other modifications to the Xdriver code e.g support for different line-widths.
> If someone needs my version of the Xdriver please let me know.
> Ronald Wiemer
> Rijksdienst voor het Oudheidkundig Bodemonderzoek
> Postbus 1600
> 3800 BP Amersfoort
> tel + 31 33 4227614
> fax + 31 33 4227799
