GRASS to ARC grid projection differences
Malcolm Williamson
malcolm at cast.uark.edu
Tue Jul 18 16:08:13 EDT 2000
Alynne,
It appears your x and y have been transposed - y max is equivalent to
north, y min is equivalent to south, etc. You'll find that the
difference between y max and y min is equal to 249 * 30, as is should
be, but the starting coordinate is wrong (it's the west coordinate!).
Best regards,
-Malcolm Williamson
Alynne Bayard wrote:
> hello,
> does anyone know why there would be a large difference
> between the region specified for a grass raster file
> and the x and y min/max when it is converted to an
> arc grid? see eg./details below:
> GRASS: (utm) ARC: (utm)
> ncols 129
> nrow 249
> n 3957930 xmax 3954330
> s 3950460 xmin 3950460
> e 369040 ymax 372640
> w 365170 ymin 365170
> cellsize 30m cell 30m
> thanks...alynne.
> & Alynne Bayard (alynne at cast.uark.edu) &
> & Research Assistant - Tree-Ring Laboratory &
> & Ancient Cross Timbers Project &
> & Department of Geosciences, Ozark Hall #113 &
> & University of Arkansas &
> & Fayetteville, AR 72701 &
> & tel: (501) 575-4277 ; fax: (501) 575-3177 &
> & (xtimber) http://www.uark.edu/xtimber/ &
> & {me= http://www.cast.uark.edu/~alynne} &
