Still having problems selecting monitors
Jeff P. Hollenbeck
hollenbj at ucs.orst.edu
Fri Jul 21 18:21:31 EDT 2000
Scott,
I had a problem like this, too. It happened with both v5.0b6 and b7. I
fixed it by copying the $GRASS/etc/mon.select file from my old v4.2
installation into my new v5.0 /etc directory (overwriting the v5.0
mon.select) and all works great. I can't remember how or why I arrived at
that solution, but it did fix my problem.
BTW, I use linux 2.2.13 (redhat 6.1), and compile GRASS from source.
Perhaps your setup and problem are different.
Good luck,
Jeff P. Hollenbeck
Dept. of Forest Resources
Oregon State University
Corvallis, OR 97331
On Thu, 20 Jul 2000, Scott Smith wrote:
> I am still having problems selecting monitors in grass. As before,
> starting a monitor without selecting it is no problem. However, when it
> tries to select, it just hangs. Following is the output of strace from
> when I tried to select the monitor.
> Scott Smith
> execve("/opt/grass5/bin/d.mon", ["d.mon", "select=x0"], [/* 58 vars */]) = 0
> brk(0) = 0x8081f50
> open("/etc/ld.so.preload", O_RDONLY) = -1 ENOENT (No such file or directory)
> open("/etc/ld.so.cache", O_RDONLY) = 4
> fstat(4, {st_mode=S_IFREG|0644, st_size=24965, ...}) = 0
> mmap(NULL, 24965, PROT_READ, MAP_PRIVATE, 4, 0) = 0x40015000
> close(4) = 0
> open("/lib/libm.so.6", O_RDONLY) = 4
> fstat(4, {st_mode=S_IFREG|0755, st_size=543826, ...}) = 0
> read(4, "\177ELF\1\1\1\0\0\0\0\0\0\0\0\0\3\0\3\0\1\0\0\0\0>\0\000"..., 4096) = 4096
> mmap(NULL, 118488, PROT_READ|PROT_EXEC, MAP_PRIVATE, 4, 0) = 0x4001c000
> mprotect(0x40038000, 3800, PROT_NONE) = 0
> mmap(0x40038000, 4096, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED, 4, 0x1b000) = 0x40038000
> close(4) = 0
> open("/lib/libnsl.so.1", O_RDONLY) = 4
> fstat(4, {st_mode=S_IFREG|0755, st_size=376092, ...}) = 0
> read(4, "\177ELF\1\1\1\0\0\0\0\0\0\0\0\0\3\0\3\0\1\0\0\0\3009\0"..., 4096) = 4096
> mmap(NULL, 89032, PROT_READ|PROT_EXEC, MAP_PRIVATE, 4, 0) = 0x40039000
> mprotect(0x4004b000, 15304, PROT_NONE) = 0
> mmap(0x4004b000, 8192, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED, 4, 0x11000) = 0x4004b000
> mmap(0x4004d000, 7112, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_ANONYMOUS, -1, 0) = 0x4004d000
> close(4) = 0
> open("/lib/libc.so.6", O_RDONLY) = 4
> fstat(4, {st_mode=S_IFREG|0755, st_size=4223971, ...}) = 0
> read(4, "\177ELF\1\1\1\0\0\0\0\0\0\0\0\0\3\0\3\0\1\0\0\0\200\204"..., 4096) = 4096
> mmap(NULL, 1025596, PROT_READ|PROT_EXEC, MAP_PRIVATE, 4, 0) = 0x4004f000
> mprotect(0x40142000, 30268, PROT_NONE) = 0
> mmap(0x40142000, 16384, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED, 4, 0xf2000) = 0x40142000
> mmap(0x40146000, 13884, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_ANONYMOUS, -1, 0) = 0x40146000
> close(4) = 0
> mprotect(0x4004f000, 995328, PROT_READ|PROT_WRITE) = 0
> mprotect(0x4004f000, 995328, PROT_READ|PROT_EXEC) = 0
> munmap(0x40015000, 24965) = 0
> personality(PER_LINUX) = 0
> getpid() = 350
> brk(0) = 0x8081f50
> brk(0x8081f70) = 0x8081f70
> brk(0x8082000) = 0x8082000
> umask(022) = 022
> ioctl(0, TCGETS, {B9600 opost isig icanon echo ...}) = 0
> access("/opt/grass5/etc/bin/main/cmd/d.mon", F_OK) = 0
> execve("/opt/grass5/etc/bin/main/cmd/d.mon", ["d.mon", "select=x0"], [/* 58 vars */]) = 0
> brk(0) = 0x80854cc
> close(4) = 0
> mmap(NULL, 89032, PROT_READ|PROT_EXEC, MAP_PRIVATE, 4, 0) = 0x4001c000
> mprotect(0x4002e000, 15304, PROT_NONE) = 0
> mmap(0x4002e000, 8192, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED, 4, 0x11000) = 0x4002e000
> mmap(0x40030000, 7112, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_ANONYMOUS, -1, 0) = 0x40030000
> close(4) = 0
> mmap(NULL, 118488, PROT_READ|PROT_EXEC, MAP_PRIVATE, 4, 0) = 0x40032000
> mprotect(0x4004e000, 3800, PROT_NONE) = 0
> mmap(0x4004e000, 4096, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED, 4, 0x1b000) = 0x4004e000
> close(4) = 0
> close(4) = 0
> getpid() = 350
> brk(0) = 0x80854cc
> brk(0x80854ec) = 0x80854ec
> brk(0x8086000) = 0x8086000
> open("/users/smit/.grassrc5", O_RDONLY) = 4
> fstat(4, {st_mode=S_IFREG|0666, st_size=119, ...}) = 0
> mmap(NULL, 4096, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_ANONYMOUS, -1, 0) = 0x40015000
> read(4, "GISDBASE: /users/smit/gis\nLOCATI"..., 4096) = 119
> read(4, "", 4096) = 0
> close(4) = 0
> munmap(0x40015000, 4096) = 0
> access("/users/smit/gis/Boston", F_OK) = 0
> stat("/users/smit/gis/Boston/PERMANENT", {st_mode=S_IFDIR|0777, st_size=1024, ...}) = 0
> getuid() = 18369
> geteuid() = 18369
> getuid() = 18369
> geteuid() = 18369
> umask(022) = 022
> close(4) = 0
> rt_sigaction(SIGINT, {SIG_IGN}, {SIG_DFL}, 8) = 0
> rt_sigaction(SIGQUIT, {SIG_IGN}, {SIG_DFL}, 8) = 0
> rt_sigprocmask(SIG_BLOCK, [CHLD], [], 8) = 0
> vfork() = 351
> wait4(351,
