Trouble importing data
    Michel Wurtz - ENGEES/CEREG
    mw at engees.u-strasbg.fr
    Thu Jun 15 04:42:41 EDT 2000
Scott Smith wrote:
> I finally managed to get GRASS started and running.  My next task is to
> import a few Arc/Info coverages to form the basemap for a project.
> However, whenever I try anything like
>          m.in.e00 help
> I get the message
>           ERROR: LOCATION_NAME not set
Hmm, this is a message displayed by the grass library when a program
test the environment variables (including $LOCATION).
After starting the Grass shell, look at what the command "/bin/echo $LOCATION"
"/bin/echo $LOCATION_NAME", etc.  give.  Use "/bin/echo" because the problem
may also be that variable are set but not exported (thus not available for
the programs you run)
Here is an exemple of the environment variables when you run Grass :
GISBASE=/home/local/grass-5.0
GISDBASE=/home/grass-data
GISRC=/home/mw/.grassrc5
GIS_LOCK=6829
LOCATION=/home/grass-data/drain-bv/PERMANENT
LOCATION_NAME=drain-bv
MAPSET=PERMANENT
You should have the same error with many other programs, not only m.in.e00.
> I am running precompiled grass4.3 on a Linux system.
What kind of unix system ? what shell (sh, csh, bash, tcsh,...) are you using ?
Michel Wurtz    ENGEES - CEREG
                1, quai Koch - BP 1039, F-67070 STRASBOURG cedex
                Tel: +33 03.88.24.82.45  Fax: +33 03.88.37.04.97
