distorted image
    Bruce Byars
    Bruce_Byars at baylor.edu
    Wed Mar  8 00:18:08 EST 2000
Antonio,
Use i.rectify and i.points to rectify your image.  You may also want to
check the
resolution of your data with g.region as well.
Bruce
Bruce Byars
GRASS Dev. Team
CAGSR - Baylor Univ.
Antonio Rodríguez Verdugo wrote:
> Hi All,
> I have an image in .ras format. I imported within grass with
> r.in.sunrast. Then I ran r.support and fixed the coordinates. But if I
> try to see it I get always a distorted image. I've tried to manage the
> number of cols and rows, change the resolution and every imaginable
> procedure, but there is no way. What I'm doing wrong?
> Antonio
> Paraje Natural Marismas del Odiel
> Centro de Calatilla
> Huelva, Spain
> rod.chav at hsoft.es
