v.in.arc: error reading file
D D Gray
ddgray at armadce.demon.co.uk
Wed Mar 8 12:02:30 EST 2000
Can anyone tell me what is wrong with the included text file[s].
I am trying to import a simple ungen file set with v.in.arc. But when
I run v.in.arc with the text file option it doesn't import giving the
error:
v.in.arc: Coverage type = polygon
The LABEL-TEXT file has been scanned. There are 15
lines in the file and 3 columns in the file
Working...
ERROR: Reading LABEL-TEXT or LABEL-POINTS file
It imports the lines file OK (without the text_in option.)
The command is:
v.in.arc lines_in=simple.pol points_in=simple.lab \
text_in=simple.txt vector_out=simple idcol=1 catcol=3 type=polygon
I've tried both GRASS4.2.1 and GRASS5beta6, also with
an optional 'END' line on each file in all combinations.
Also it says 15 lines: I count 14. . .
Any help appreciated.
D Gray
1 259472.730470 588192.056905
2 260443.056664 588179.138945
3 260410.350709 588745.998342
4 258148.201913 587502.809681
5 258482.553486 588840.383168
6 259345.286876 589426.973467
7 257752.257272 588833.581309
8 257430.543893 587159.065358
9 260555.648614 587132.656503
10 261383.414252 587096.098164
11 260976.702736 588644.661702
12 260931.004812 588297.953545
13 260536.623317 588789.985773
14 257294.153953 588896.596340
1 1 0
2 2 3
3 3 6
4 4 2
5 5 7
6 6 11
7 7 3
8 8 4
9 9 8
10 10 3
11 11 1
12 12 3
13 13 7
14 14 2
