Fw: Makefile help
Markus Neteler
neteler at geog.uni-hannover.de
Sat Mar 11 14:10:56 EST 2000
Hi all,
the new Makefile[.in] from Pavrol is uploaded
to CVS. Those having problems may upgrade.
You can also WWW-access the file:
http://freegis.org/cgi-bin/cvsweb.cgi/~checkout~/grass/Makefile.in
Please tell me if this helps for your "ENV" problem.
Thanks
Markus Neteler
On Tue, Mar 07, 2000 at 08:51:49AM -0800, Eric G . Miller wrote:
> On Tue, Mar 07, 2000 at 09:08:29AM +0000, David Armstrong wrote:
> > thanks eric ,
> > it did not seem to help here is a dump of text when doing a make
> > with no modifications to makfile just a grass ./configure makes it !.
> > [root at localhost grass5.0beta]# make
> > if [ ! -d /usr/local/grass-5.0b ]; then mkdir /usr/local/grass-5.0b ; fi
> > if [ ! -d src/CMD/next_step ]; then mkdir src/CMD/next_step ; fi
> > /root/.bashrc UNIX_BIN=/usr/local/bin SRC=`pwd`
> > GISBASE=/usr/local/grass-5.0b MACHINENAME=`uname -n` /bin/sh sr
> > c/CMD/generic/CREATE_GMAKE.sh
> > make: *** [pre-install] Error 1
> > With ENV =
> > i do not even get this far it croakes on isa64.sh or something
> (checks if you're a 64 bit machine, does 64bit stuff if true)
> > iam i reading this correct in that 'pwd' and 'uname-n' is not being set in
> > the above line etc
> > hence the error !.
> > dave
> > Linux Mandrake 7 OS
> Well, I don't know what the problem could be. Those `pwd` and `uname -n`
> will be expanded later -- so they're okay. The output sure isn't being
> very helpful :-(.
> You can compile other programs? src/CMD/generic/CREATE_GMAKE.sh exists
> and has the executable bit set? There's just not much to go on...
> | Eric G. Miller egm2 at jps.net |
> | GnuPG public key: http://www.jps.net/egm2/gpg.asc |
