GIS.sh and bash
    Moritz Lennert
    mlennert at club.worldonline.be
    Tue May  2 13:38:43 EDT 2000
That was it, thank you !
But I believe this info should be "INSTALL" instructions that come with
the source code.
Moritz
On Tue, 2 May 2000, Markus Neteler wrote:
> On Mon, May 01, 2000 at 07:31:28PM +0200, Moritz Lennert wrote:
> > Is the old GIS.sh and bash problem solved in 5.0b or do I need to get a
> > special GIS.sh ? For the moment I get the following error messages when
> > trying to connect to a location I just created:
> Hi Moritz,
> it is solved for GRASS 5.x and 4.2.1 and 4.3. I will remove
> the message from FAQ.
> > /usr/local/grass-5.0b/etc/GIS.sh: g.gisenv: command not found
> > /usr/local/grass-5.0b/etc/GIS.sh: g.gisenv:command not found
> > /usr/local/grass-5.0b/etc/GIS.sh: GISDBASE: parameter null or not set
> I guess after compiling you did not run
> gmakelinks5
> Cheers
>  Markus
