libc.so gets() warning on FreeBSD
    James Cameron
    quozl at us.netrek.org
    Thu May 25 19:24:16 EDT 2000
On Fri, May 26, 2000 at 04:14:32AM +0900, User for GRASS wrote:
> GRASS 4.2 uses gets() function, which is unsafe, many times and
> libc.so warns this every gets() call. There are so many garbage output.
> You should rebuild standard c library.
Isn't there a library that GRASS uses that you could define a replacement
gets() in that uses fgets() instead?  Changing libc seems brutal.
James Cameron    mailto:quozl at us.netrek.org     http://quozl.netrek.org/
