[GRASSLIST:1081] Re: problems with r.in.ppm, r.in.tiff
Bernhard Reiter
bernhard at intevation.de
Fri Nov 3 12:29:36 EST 2000
On Thu, Oct 19, 2000 at 02:49:59PM -0700, an lu wrote:
> Hi GrassUser,
> i am a beginner of Grass.i try to import a ppm or tiff
> picture into Grass using r.in.tiff or r.in.ppm.
> i drawed the picture using XFig, and exported it as
> *.ppm. then i used r.in.ppm, i got an error
> information: unknown ppm magic number.
pnm is a group of file formats. As for ppm I only now
that there are two versions: text and binary encoding.
The manual pages of the pnm tools will answer your questions about the
format.
Check the header of the two images and try to convert your ppm image
into the other ppm format.
I think some pnm tools or convert from the ImageMagick kit can do this.
Bernhard
> i try to import the ppm picture which is exported from
> grass back to Grass again, and it works.
> from the rmanual, i read that r.in.ppm can convert ppm
> raster file into raster file. i guess maybe i need to
> convert a pure ppm file into ppm raster first, could
> you tell me how to do that? if that is not the reason,
> what i need to do?
> Thanks.
> --lu
> __________________________________________________
> Do You Yahoo!?
> Yahoo! Messenger - Talk while you surf! It's FREE.
> http://im.yahoo.com/
Professional Service around Free Software (intevation.net)
The FreeGIS Project (freegis.org)
Association for a Free Informational Infrastructure (ffii.org)
Name: not available
Desc: not available
Url : http://lists.osgeo.org/pipermail/grass-user/attachments/20001103/96bb54c8/attachment.bin
