[GRASSLIST:1161] Re: r.proj questions
Eric G . Miller
egm2 at jps.net
Mon Nov 20 21:31:06 EST 2000
On Mon, Nov 20, 2000 at 04:58:22PM -0800, Jeshua Lacock wrote:
> Hello all,
> Looking at the manual page, I am confused about the following r.proj
> parameters:
> input=name (Input raster map from source location.)
The simple name of the source raster in the other location.
> location=name (Source location of input map.)
Yes.
Also you may specify the mapset=<name> if it's possible you have the
same input raster name in different "mapsets" of the same "location"
(confused?).
> I assume one parameter is the unix file path and one is the grass
> raster object name?
> dbase=name (Database of input map)
> Is dbase expected to be the unix path of the DB or just the DB name?
If it's in a different GRASS database (yes, a directory path). This is
optional. For myself, I only use one GRASS database with several
locations/mapsets. Easiest that way. However, the data could be
located elsewhere in multiuser scenarios.
Eric G. Miller <egm2 at jps.net>
