Hello Stefano, just a hint: The current GRASS 5 version in CVS (not yet released in a package) contains an updated version of v.surf.rst which can be used to interpolate raster surfaces from contours using a Spline algorithm. The results will be better than from r.surf.contour (probably it's not faster...). Kind regards Markus Neteler
