watershed surface area
Eric G . Miller
egm2 at jps.net
Tue Oct 17 03:16:23 EDT 2000
There's a r.surf.area (at least in 5.0), but it has a couple problems
which I'm working on. Doesn't consider NULL area properly (it's
included) and only works with CELL rasters. I hope to get this fixed-up
for the upcoming release of GRASS 5.0 (stable).
On Mon, Oct 16, 2000 at 11:23:49PM -0700, David Finlayson wrote:
> I'd be suprised if one of the watershed models doesn't
> provide this, but you should be able to get it easily
> enough for any point on your DEM by computing the
> slope of each cell with r.slope.aspect and storing
> that in a slope_grid. Then use the following formula
> in r.mapcalc (I think this will work):
> area_grid = ewres()* nsres()/cos(slope_grid)
> This gives you the surface area of each cell. Next use
> this grid as the flow grid in r.watershed and create
> the accumulation grid which should tally up the _true_
> contributing area of each cell in your DEM. Use masks
> if you are only interested in a sub-basin.
> --- Rado Bonk <rado at cosmos.dsc.unomaha.edu> wrote:
> > Hi GRASSusers,
> > Is there a way to compute watershed surface area in
> > GRASS? In
> > mountain regions it differs a lot from that of
> > planimetric area.
> > -Rado Bonk
> > Rado Bonk
> > Geography and Geology
> > UNO, Nebraska, 68182-0199,
> > rado at cosmos.unomaha.edu
> David Finlayson
> david_finlayson at yahoo.com
> University of Washington
> Box 351310
> Seattle, WA 98195 - 1310
> __________________________________________________
> Do You Yahoo!?
> Yahoo! Messenger - Talk while you surf! It's FREE.
> http://im.yahoo.com/
/bin/sh ~/.signature:
Command not found
