d.rast question in 5.0b8
Eric G . Miller
egm2 at jps.net
Fri Oct 20 23:14:34 EDT 2000
On Fri, Oct 20, 2000 at 10:47:18PM -0400, Timothy Reaves wrote:
> When I have open a monitor window, and use the d.rast command, the
> display window is not updated when some other window overlays it then is
> moved. Is this non repainting behavior normal?
No, it's not normal. Are you using X 4.0.x ? Markus Neteler reported
this problem recently. Seems there's a config change that might work:
<excerpt>
It seems exposure events not being generated.
One trivial way could be to enable backing-store in the X server
(more memory needed by X)
In /etc/X11/xdm/Xserver
change a line like this
:0 local /usr/X11R6/bin/X
to
:0 local /usr/X11R6/bin/X -wm
<end exerpt>
/bin/sh ~/.signature:
Command not found
