d.rast question in 5.0b8
Timothy Reaves
treaves at silverfields.com
Sun Oct 22 21:10:50 EDT 2000
I am running 5.0b8 (as per my subject line :-} ). I am running
Accelerated X, not XFree86, but that was the problem. I tuned on the backing
store and it works now.
Thanks.
"Eric G . Miller" wrote:
> On Fri, Oct 20, 2000 at 10:47:18PM -0400, Timothy Reaves wrote:
> > When I have open a monitor window, and use the d.rast command, the
> > display window is not updated when some other window overlays it then is
> > moved. Is this non repainting behavior normal?
> No, it's not normal. Are you using X 4.0.x ? Markus Neteler reported
> this problem recently. Seems there's a config change that might work:
> <excerpt>
> It seems exposure events not being generated.
> One trivial way could be to enable backing-store in the X server
> (more memory needed by X)
