s.out.ascii
Eric G . Miller
egm2 at jps.net
Tue Sep 19 07:27:08 EDT 2000
On Tue, Sep 19, 2000 at 12:35:26PM +0200, mlennert at club.worldonline.be wrote:
> Hello,
> In tcltkgrass there seems to be the same problem with the 'fs' switch
> for s.out.ascii as in s.in.ascii: the switch is not in quotes and
> therefore ignored by s.out.ascii. When I try to put the seperator in
> quotes I get an error message.
> Moritz
I don't see this behavior. It seems to work the same in tcltkgrass as at
console (except metachars need to be escaped at console \|, etc.). I do
notice the tcltkgrass interface does not have an option for including
the site attribute identifier (# or % or @) in the output.
As to your previous message: the category number should not be
obligatory. However, s.in.ascii has some bad behaviours. It seems to
give you a category number if there's none *and* create a double
attribute with a value of zero. Since the spec says the cat number is
optional, as are any attributes, this is definitely a bug.
I'll look at it and see if I can't propose a fix.
/bin/sh ~/.signature:
Command not found
