5.0beta8 bin directory read/write permissions?
David Finlayson
david_finlayson at yahoo.com
Fri Sep 22 11:32:19 EDT 2000
I have a binary install of 5.0beta8 installed to
/usr/local/grass-5.0b on a Debian potato linux box.
This directory is not writable (except by root). I
just tried to run r.watershed and it failed with the
following message:
SECTION 1 beginning: Initiating Variables. 6 sections
total
segments in row: 622
segments in columns: 277
total segments: 172294
open segments: 213
WARNING: No such file or directory
WARNING: seg_open(): could not write segment file
ERROR: <</usr/local/grass-5.0b/etc/water/seg
el="elv at elwha" t=1000000
ba="basins" ac="flowacc" se="streams"
ha="halfbasin" di="flowdisp"
S="steepness" r=0 ms=150>> command line failed
It appears that it tried to write into /usr . Do I
need to move the grass binaries to a directory where
it can write to itself?
g.manual also fails due to a permission problem. Is
this related?
Thanks for any help you can give
David Finlayson
__________________________________________________
Do You Yahoo!?
Send instant messages & get email alerts with Yahoo! Messenger.
http://im.yahoo.com/
