[GRASSLIST:1692] g.region
Gail Higginbottom
ghigginb at physics.adelaide.edu.au
Tue Apr 3 07:28:24 EDT 2001
Dear grass members,
I seem to be successfully importing reems of OS data via r.in.ntf,
however, after running g.region and then r.in.ntf I get the following
message in the r.in.ntf output window
NOTE: Some or all of the input data falls outside both the
CURRENT and DEFAULT regions. The output map contains all
the data, but you must change the current region to use
it. You may also wish to ask the owner of the location to
change the default region.
My question is, "is this a standard note"? I am not sure that I
understand how to change the current region to use all the data?
Am I missing the point?!
Please help if you can.
best wishes,
Gail.
Gail Higginbottom,
Centre for European Studies and General Linguistics,
University of Adelaide,
Adelaide, South Australia,
Australia. 5005.
and
Department of Physics and Mathematical Physics
http://www.physics.adelaide.edu.au/~ghigginb/
(08) 8303:6440
