[GRASSLIST:1725] Re: EGM96 geoid model?
Eric G. Miller egm2 at jps.net
Tue Apr 10 10:41:52 EDT 2001
On Tue, Apr 10, 2001 at 09:14:26AM +0100, Markus Neteler wrote:
> Hi all,
> as Dieter Lehmann has some DNS problems, I am forwarding his mail:
> Resent-To: GRASSLIST at baylor.edu
> Date: Mon, 09 Apr 2001 14:03:36 +0200 (CEST)
> From: Dieter Lehmann <lehmann at fh-nuertingen.de>
> Subject: FW: EGM96
> Hello,
> (this message might come twice, I get a returned mail because of an not
> reachable DNS-Server).
> I need some advice in the area of projections...
> How to create a location with the following attributes:
> Projection: UTM
> Horizontal Datum: WGS84
> Geoid Model: EGM96 (thats the problem)
> Vertical Reference Mean Sea Level (MSL)
> It seems, that GRASS have no idea about EGM96, is there another Geoid-name
> with the simular specifications?
> Is the way correct to import the data into an UTM location, create a
> Gaus-Krueger location and import the data from the UTM-location with
> r.proj?
WGS84 is both a horizontal and vertical datum.  GRASS won't do anything
with the GEOID info anyway.  Presumably, if the heights reference Mean
Sea Level, then they've already been corrected for GEOID offsets ??
Probably good to maintain the info, but GRASS won't use it for
anything...
Eric G. Miller <egm2 at jps.net>
