[GRASSLIST:1743] Re: Scripting and Locations...
Markus Neteler
neteler at geog.uni-hannover.de
Mon Apr 16 15:54:10 EDT 2001
On Mon, Apr 16, 2001 at 10:39:22AM -0400, mberglund wrote:
> Howdy folks,
> Could someone tell me if there is a way to create a new location and
> mapset from the command line.
> I am writing a batch job to process a ton of imagery and the most
> cost(time/cpu) effective way I have found to do this requires creating a
> new location for every image and then importing the result into the final
> map.
> Thanks ahead,
> Matt
Hi Matt,
you can use (GRASS 5): r.in.gdal
The "-e" flag and "location=" parameter allow to generate a
new location through another, different location.
But: if your input data do not provide projection data, you have
to set this with g.setproj later within the new location.
See here as well:
http://www.geog.uni-hannover.de/grass/gdp/html_grass5/html/r.in.gdal.html
Cheers
Markus Neteler
