[GRASSLIST:1766] Re: list GRASSLIST: List Message Rejected
Glynn Clements glynn.clements at virgin.net
Wed Apr 25 12:41:01 EDT 2001
grass at anon.tuxers.net wrote:
> Also, if I try to change to float color mode with d.colormode, it says
> "Sorry, floating color table not available on this device".  Is this not
> yet supported, or do I need to change my monitor window?
It requires a PseudoColor visual; it won't work on a display which
only has TrueColor visuals. For most systems, this translates to "you
have to use 8-bpp".
Glynn Clements <glynn.clements at virgin.net>
